Need help with optimizing
Jackie_
I want to optimize the calculation. I tried both Col Formula and Loop but neither of them seem to be faster for rows > 10k.
I compared the exe speed and both of them take a very long time
Col Formula = 500.46s;
Loop = 491.70s;
Is there a way to optimize using Matrix or J trans?
testColumn = Column( "Test_A" );
slidervalue = 6;
////UsingFormula
start = Tick Seconds();
dt << New Column( "LL_formula",
	Numeric,
	Continuous,
	Formula(
		If( Row() < 200, // Skip the first 200 rows
			current_device = :DeviceNumber;  // Get the current site number
			current_site = :SiteNumber;
											// Get the indices of rows that match the current SiteNumber
			matching_rows = Where( :DeviceNumber == current_device | :SiteNumber == current_site );
           // Determine the start and end positions for the moving window
			start_row = Max( 1, Row() - 199 );
			end_row = Row();
           // Get the moving window data for matching rows
			m = Subscript( Expr( testColumn ), matching_rows[Loc( matching_rows >= start_row & matching_rows <= end_row )] );
											//m = testColumn[Max( 1, Row() - 199 ) :: Row()];
			// Calculate the quantiles and IQR
			q1 = Quantile( 0.25, m );
			q3 = Quantile( 0.75, m );
           // Calculate the lower limit using the sigma function
			q1 - (q3 - q1) * (slidervalue - 0.675) / 1.35;
dt << New Column( "UL_formula",
	Numeric,
	Continuous,
	Formula(
		If( Row() < 200,
			.,  // Skip the first 200 rows
			end_row = Row();
           // Calculate the upper limit using the sigma function
			q3 + (q3 - q1) * (slidervalue - 0.675) / 1.35;
end = Tick Seconds();
Show( end - start );
///UsingLoop
start2 = Tick Seconds();
llColX = dt << New Column( "LL_loop", Numeric );
ulColX = dt << New Column( "UL_loop", Numeric );
For Each Row(
	dt,
	If( Row() < 200,
		current_device = :DeviceNumber[Row()];  // Get the current site number
		current_site = :SiteNumber[Row()];
		end_row = Row();
		m2 = Subscript( testColumn, matching_rows[Loc( matching_rows >= start_row & matching_rows <= end_row )] );
		q1 = Quantile( 0.25, m2 );
		q3 = Quantile( 0.75, m2 );
		llColX[Row()] = q1 - (q3 - q1) * (slidervalue - 0.675) / 1.35;
	If( Row() < 200,
		end_row = Row();
		m = Subscript( testColumn, matching_rows[Loc( matching_rows >= start_row & matching_rows <= end_row )] );
		ulColX[Row()] = q3 + (q3 - q1) * (slidervalue - 0.675) / 1.35;
end2 = Tick Seconds();
Show( end2 - start2 );
Re: Need help with optimizing
There are still things which could be improved but this took 10-15s on my PC
dt = Open("$DOWNLOADS/sample_table.jmp");
slidervalue = 6;
ds = dt[0, "DeviceNumber"];
ss = dt[0, "SiteNumber"];
m1 = J(1, N Rows(dt), .);
m2 = J(1, N Rows(dt), .);
For Each Row(dt,
	If(Row() < 200,
		d = :DeviceNumber[Row()];
		s = :SiteNumber[Row()];
		rs = (Row() - 199)::Row();
		d1 = ds[rs];
		s1 = ss[rs];
		r = where(s1 == s | d1 == d);
		vals = dt[rs[r], "Test_A"];
		q1 = Quantile(0.25, vals);
		q3 = Quantile(0.75, vals);
		m1[Row()] = q1 - (q3 - q1) * (slidervalue - 0.675) / 1.35;
		m2[Row()] = q3 + (q3 - q1) * (slidervalue - 0.675) / 1.35;
llColX = dt << New Column("LL_loop1", Numeric, Continuous, Values(m1));
llColX = dt << New Column("UL_loop2", Numeric, Continuous, Values(m2));
Show(end2 - start2);
First things to try are to utilize private/invisible table with << begin data update and << end data update. After that has been tried, then it might be a good idea to move into other methods
Jackie_
Tried using begin/end data update and it made it worse
Total time : 780.73s
slidervalue = 6;
///UsingLoop
dt << show window( 0 );
dt << begin data update;
For Each Row(
	dt,
	If( Row() < 200,
		end_row = Row();
	If( Row() < 200,
		end_row = Row();
dt << end data update;
slidervalue = 6;
For Each Row(dt,
	If(Row() < 200,
		d1 = ds[rs];
		s1 = ss[rs];
You might want to use the Debugger and Profiler in JMP to determine where the script spends most of its time.
