DELANDJ1985
Counting Formulas
Looking to create 3 cols by col variable to could down with change, count up and count up/down from mid point.
Re: Counting Formulas
Is something like this what you are looking for?
"Down"
Col Cumulative Sum(Row() == Col Min(Row(), :Lot))
"Up"
Col Sum(Row() == Col Min(Row(), :Lot)) - Col Cumulative Sum(Row() == Col Min(Row(), :Lot)) + 1
Middle
Col Cumulative Sum(Row() == Col Min(Row(), :Lot)) - Col Sum(Row() == Col Min(Row(), :Lot)) + 1
Jarmo's response is the correct answer, if the Lots are always contiguous.   However, if the grouping column is not contiguous, such as
A
A
A
B
B
A
A
C
C
C
then the provided formulas will not be correct.  Here are alternative formulas that handle noncontiguous groupings
Down
As Constant( count = 0 );
If( :Lot != Lag( :Lot ),
	count
count;
Up
As Constant(
	count = 0;
	For Each Row( If( :Lot != Lag( :Lot ), count++ ) );
	count = count + 1;
	count
count;
Middle
As Constant(
	count = 0;
	count = count + 1;
	count = -1 * Ceiling( count / 2 );
	count
count;
SDF1
Hi @DELANDJ1985 ,
  I had a slightly different take on how to do it than @jthi and @txnelson . See the attached jmp file where I defined separate column formulas for each counting scheme. I did each one slightly differently so you could take the concept and perhaps modify it to your specific issue at hand. There might even be more than one possible answer to your query!
  You don't have to make a column formula, but could script it up and run it as a script so the column isn't locked. But, that detail depends on the needs of your specific scenario.
Hope this helps!,
DS
