Ribs11380
Need One Column to be both a Character and Numeric Data Type
Hi Everyone-
      I'm a fairly new user of JMP 17 Pro, and I am working on a project where I have one column of data that I need to have as both a Character Data Type AND as a Numeric Data Type. I need both columns as I want to 1)  concat two different columns together (using Character) while at the same time having this same data as Numeric in a second column. Currently if I change the one column to Character I am able to successfully use the Concat function but then after I create this I go to change the column to Numeric my Concat column goes blank on me. Thank you for your help!
Re: Need One Column to be both a Character and Numeric Data Type
You can concatenate together your Character Worksheet column with your Numeric Date column by using the following formula
:Character Worksheet || "_" || Format(
	:Numeric Date,
	"ddMonyyyy",
	9
or in using the Concat() function
Concat( :Character Worksheet,  "_",
	Format( :Numeric Date, "ddMonyyyy", 9 )
The Format() function returns the date as a character string
StarfruitBob
@Ribs11380
Could you post a mockup of what you have and what you want?
When concatenating columns, the inputs and outputs are a character type.  If you wrap your concatenation in num( your concat formula here ), in the formula editor, if the resulting data is able to be converted into a number, it will be.  If you force a character type to become a number via column properties, it will be erased because character types are not numbers.
Learning every day!
@StarfruitBob  points out the num(...) function will convert character data to numeric. There is also a char(...) function that converts numeric data to character.
You might want to use a formula column for the concatenation of two numeric columns. The formula column's formula might be
char(a) || char(b)
for the numeric columns a and b. You'll probably want to keep numeric data in numeric columns for further work. Converting it to character will cause platforms like fit y by x to produce the wrong report for numeric data.
Name is a character variable that will make logistic, contingency, or oneway plots depending on which axis it is used on, and the type of the other axis.Name is a character variable that will make logistic, contingency, or oneway plots depending on which axis it is used on, and the type of the other axis.
Fix Y by X produces the expected Bivariate for two numeric columns.
Ribs11380
Thanks to you both for reaching out! I have attached a mock example of what I am trying to do. Basically I need both worksheet and Date to be available in both Numeric and Character so I can concat both together to get my desired result:  Ex: 1_24May2023, 2_25May2023, etc. Under the Concat Worksheet and Date Column. I am ok with having additional columns with the same data as well so for instance having Character Worksheet having a new column created and it can be labelled Numeric Worksheet and vice versa with Numeric Date with creating a new column labelled Character Date. It seems so simple but I'm just able to do something as easy as Insert a New Column and then Paste the Column into a new column and rename.
vince_faller
This seems like an XY problem.  What are you actually trying to do?
Vince Faller - Predictum
	:Numeric Date,
	"ddMonyyyy",
	9
right-click the top of the new column, pick formula from the pop up menu. Add the formula to do what you need.
the || is the concatenation operator. There are a bunch of date formats you can choose from.the || is the concatenation operator. There are a bunch of date formats you can choose from.
Right-click a column->Column Info is the way I usually re-discover the format names. I'd recommend making names that sort well for most purposes; probably put the year first, then month, day, and sheet number last. Unless you need all the sheet 1s to sort together.
the datetime formats are in a separate category.the datetime formats are in a separate category.
