Jackie_
Scale axis fit group
Hello JMP Community,
I am trying to write a jsl code that can scale the axis with button box.
I want to scale axis for all three oneway plots in the fit group.
The below code works only for the first one way chart.
Any suggestions?
New Window( "",
	H List Box(
		Button Box( "Scale axis   ",
			Try( fsl = fg << report );
			(fsl)[AxisBox( 1 )] << Min( 20 ) << Max( 100 );
		V List Box(
			fg = Fit Group(
				Oneway( Y( :height ), X( :name ) ),
				Oneway( Y( :height ), X( :age ) ),
				Oneway( Y( :height ), X( :sex ) ),
				<<{Arrange in Rows( 1 )}
Thanks,
Jackie
Re: Scale axis fit group
You could get the references to Axisboxes with XPath. The XPath I use here is most likely not robust enough and should be improved
nw = New Window("",
	H List Box(
		Button Box("Scale axis   ",
			Try(fsl = fg << report;
				axisboxes = fsl << XPath("//AxisBox");
				axisboxes[1::N Items(axisboxes) - 1::3] << Min(20) << Max(100);
		V List Box(
			fg = Fit Group(
				Oneway(Y(:height), X(:name)),
				Oneway(Y(:height), X(:age)),
				Oneway(Y(:height), X(:sex)),
				<<{Arrange in Rows(1)}
Or you can get references to outline boxes and then loop the AxisBox(1)
ows = fg << XPath("//OutlineBox[contains(text(), 'Oneway Analysis of')]");
For Each({ow}, ows,
	ow[AxisBox(1)] <<Min(10) << Max(150);
nw = New Window("",
	H List Box(
		V List Box(
			fg = Fit Group(
For Each({ow}, ows,
Jackie_
Awesome! Thanks a lot Jarmo!
