GunhildNovo
My Project does not save datatables and graphs, when it is copied
Dear fellow JMP-users
I am trying to copy a JMP-project to a new location - I have succeeded with one of my projects already - data tables are available and graphs are shown as in the original file and the file size indicates, that they are saved to the project - it contains both embedded and locally saved data tables - everything works when my colleagues open the project.
The one that is causing me trouble works perfectly, when I open it on my own PC, but does not work when my colleagues open it. The file size is low, indicating that the data tables and graphs are not saved in the project. It contains locally saved data tables, but I did copy those to the new location.
I work in JMP 16.2.0
Any tips, on what is wrong, and how I might fix it?
BR
Gunhild
Level XIII
Re: My Project does not save datatables and graphs, when it is copied
For the missing data tables ...
Maybe they are just referenced in the project but not part of the project?
Do they show up in the content menu? If not, please add them to the project:
GunhildNovo
And this project contains virtual joins between data tables...
Level XIII
GunhildNovo
Thank you!
That was an easy fix :)
I do, however, still wonder why my other project worked - it did not have the data tables in "Content" either...
BR
Gunhild
Level XIII
For the other project ...
The table is loaded from the file system.
Maybe the relative path from the project to the table was the same for this file - and still worked for the copy?
GunhildNovo
Mmm... That might be - I have ensured that the data tables in both projects are in content - and I'll leave the contemplating to the IT-Gods :)
Thank you for your help :)
