mvanderaa1
Graph builder box plot creates duplicate data points
I am trying to achieve a box plot graph where the confidence diamond and data points are shown in black, with the boxes itself using the color based on a column value. Additionally, I would like to show the raw data points with a jitter.
I am using a work-around suggested to me in a previous post:
How-to-change-all-box-plot-confidence-diamonds-colors-in-graph
That solution uses two multiple box plots on top of each other to allow for a different color for the box plot and its confidence diamond.
It mostly works, but the problem I still face is that potential outliers are now showing as two separate data points.
an example using big class.jmp
the code for this graph:
Graph Builder(
	Size( 1845, 897 ),
	Show Control Panel( 0 ),
	Variables( Y( :weight ), Group X( :sex ), Color( :sex ) ),
	Elements(
		Box Plot( Y, Legend( 7 ), Box Style( "Solid" ), Fences( 0 ) ),
		Points(
			Y,
			Color( 0 ),
			Legend( 6 ),
			Jitter( "Random Uniform" ),
			Jitter Limit( 0.3179 )
		Box Plot( Y, Color( 0 ), Legend( 8 ), Confidence Diamond( 1 ) ),
		Bar( Y, Legend( 9 ), Bar Style( "Float" ), Label( "Label by Value" ) )
		Dispatch( {}, "400", LegendBox,
			{Legend Position(
				{7, [-1, 0, 1, -3], 6, [-1], 8, [-3, -3], 9, [-3, -3]}
Is there a way to achieve this? I suppose it requires not drawing the box plot potential outlier, but I can imagine this is hard to do.
Re: Graph builder box plot creates duplicate data points
The Jitter setting of "Random Uniform" appears to be the issue.  Change the setting to "Auto" and the jittering is there and without duplicate data points.  You need to contact JMP Support and put in the issue.  It seems to be a real Bug.
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
Graph Builder(
	Size( 1845, 897 ),
	Elements(
		Points(
			Y,
			Color( 0 ),
			Legend( 6 ),
			Jitter( "Auto" ),
			{Legend Position(
mvanderaa1
In case of jitter=auto, the data points simply overlap right?
Sadly I much prefer the "jitter=random uniform" aesthetics of the graphs.
I will contact JMP support regarding this issue.
