billkopp
Multivariate Correlations - "Make into Data Table" JMP script?
From the Correlations table in a Multivariate analysis I can right click and "Make into Data Table". (This makes a new table of the r values.) Using a JMP script, how can I get that correlation table of r values?
ms
Super User (Alumni) ms
Re: Multivariate Correlations - "Make into Data Table" JMP script?
The trick is to find the right item in the display tree to send the message "Make into Data Table" to. If unknown, it is a good to begin with right-clicking on an outline box and select Edit ->Show Tree Structure. The tree structure often clearly reveals how deep one must traverse to find the target display box.
A Multivariate example:
mv = dt << Multivariate(Y(:height, :weight));
Report(mv)[Outline Box("Correlations")][1, 1] << make into data table;
ms
