Iheartjmp
Multiple spec limits on chart
How can I add multiple spec limits to control chart builder? I have incleded an example of what I would like my chart to look like. I am not intrested in UCL and lower control limt but rather the spec limits.ex1.jpgex1.jpg
Re: Multiple spec limits on chart
If you are not using a control chart, then you might make a run chart with Graph Builder and add reference lines for the specifications.
Iheartjmp
Is there another way to do it do, so that I do not have to add every reference line for every spec limit? Just wondering because I have many charts and each one will need 4 reference lines.
You can actually use column properties, "Spec Limits" and specify "Show Limits" to display one set of limits on your Control Chart, and set your other set of limits to the column property "Response Limits" and also set those limits to be shown on the graph as reference lines.  That may get you what you want4limits.PNG4limits.PNG
Iheartjmp
Thank you for the response,
I found that the easiest way was to use the graph bulder add the reference lines and then copy the script but changing the varibels.
