Tohar
Multiple regression with dummy variables
How can I select intercept in multiple regression?
I want two lines to cross the Y axis in the (0,100) point.
Thanks
Tohar
11 REPLIES 11
Re: Multiple regression with dummy variables
I assume that you selected Analyze > Fit Model to start the multiple regression. A check box is at the center of the bottom of the launch dialog. Select it to remove the intercept from the model
Level XIII
This post describes how to use the Fit Y-by-X/Bivariate platform with by()  .... to collect the slopes and intercepts:
Creating-columns-from-Linear-Fit-Constants-slope-intercept
Perhaps more details are needed as I am the third to respond and I have a different take on your question. You said you wanted the lines to go through (0, 100). That is not the same as having the y-intercept of zero. You could use the nonlinear platform to build a model with a fixed y-intercept of 100 and the rest of the linear model to estimate the parameters with that restriction.
Provide a bit more clarity of your situation so that we can better assist you.
Dan Obermiller
Level XIII
Oh, thanks, I miss-read this sentence.
In the Fit Y - by - X / Bivariate Platform there is also an option to set the intercept to a fixed value:
Constrain intercept to
Tohar
I'm trying to do a multivariable linear regression. A continuous variable explains -X and a continuous variable is explained -Y and another dummy factor is categorical 0 or 1. I know that the lines should cut the Y-axis at 100 and I want to define this in the model.
 Similar to the solution in the Fit Y by X platform that "hogi" suggested but I have two lines- two groups.
Thank you very much
MRB3855
@Tohar , so it sounds like you have an ANCOVA model (one categorical factor C, and one continuous X) and you want to regress Y on these.  Define Y100 = Y-100.  then use Y100 as your response. then the only effect in your model will be C*X, with no intercept. See pic below. Also, in the red triangle pull down menu deselect "Center Polynomials".
Run this and get the following: And remember Y100 is Y-100. So, when Y100=0, Y=100. You can then get creative with Save Prediction Formula/Graph Builder/etc to get the Y axis back to the raw scale (shift it back up by 100).
Tohar
Thank you very much
I am not about the result I got; the lines cross the Y axis in (0,0) - see attached.
My goal is to check if there is a difference in rate (ie slope) between the two treatment groups. It is not necessary to check whether there is a difference in the intercept, I want to set it both in the model and in the presentation graph at (0,100).
Many thanks!!!!!
Tohar
MRB3855
@Tohar  Assuming your model is correct (I have my doubts from looking at your residual plots etc),  the p-value for the parameter estimate and/or in the ANOVA table tells the story (they are equivalent)  If less than 0.05 (that is the "usual" threshold /Type 1 error rate) then you could claim that there is a difference in slope. Strictly speaking, you are testing whether or not there is any difference from the reduced model Y100=0 (i.e, just noise). The p-value says reject the Y100= 0 model in favor of the two slope model (where slope1 = - slope2).
MRB3855
@Tohar . On second thought, use the same model with the interaction (as I said) and Days From Start.(see below). Then assess the equivalence of slopes via the p-value for the interaction parameter estimate. Adding the extra term will give more flexibility wrt the slope estimates (doesn't force slope1 = -slope2).
