gregpearce
Multiple File Import Auto-Naming Data Table
Hello All,
I'm writing a script where I start with a 'multiple file import' of a folder of .csv files. I will periodically be getting new .csv files that I would like to add. These files have a series of letters and numbers (i.e chghistory0857-786.csv, chghistory0956-783.csv, chghistory1008-805.csv, etc). The issue I'm running into is when I run the 'multiple file import' script, JMP creates a data table name that is auto named based on the .csv file names (i.e. chghistory0956-783_chghistory1008-805). When I put more data files into the folder, this name changes and messes up all future formulas.
Is there a way to pre-establish the data table name and have the data from the MFI dumped into it? JMP16 user here if that makes a difference.
Thank you,
Greg
11 REPLIES 11
Re: Multiple File Import Auto-Naming Data Table
I have the same problem!
Doesn't the provided solution provide the answer you need?
