Mi
Mi
Multidimensional Scaling Plot
Hallo,
Wie waren die Farben in Multidimensiona Scaling Plot?
nach dem Beispiel des Links
https: //www.jmp.com/support/help/en/15.1/? os = win & source = application & utm_source = helpmenu & utm_medium = a ...
eingestellt?
Danke für Ihre Hilfe.
Thierry_S
Re: Multidimensional Scaling Plot
There are multiple ways to do this:
1) Row > Color or Mark by Column
2) Column Menu > Color Properties > Value Color
3) Plot Menu > Row Legend..
Now, it you are asking about how to set the groups of color, I suspect that it was set using Clustering approach
Thierry R. Sornasse
gzmorgan0
@Mi ,
The Flight Distances.jmp data table has a table script named Hierarchical Cluster. If you run that script and select the options: Color Clusters and Number Of Clusters which will initiate a dialog. Set the number to 5.  The 5 clusters will match the color groups displayed in the .PNG and link in your post.
@Thierry_S was correct, this post just adds details.
Mi
Mi
that's how it worked!
Unfortunately I don't get a heatmap for Cluster,
even though I activated two-way clustering.
Why does this not appear?
Thanks for your help.
gzmorgan0
I was able to get a heat map. I set Number of Clusters to 5 first, then requested Two Way Clustering. ??
Mi
Mi
How can I remove the lines in the Multidimensional Scaling Plot?
Thanks.
Mi
Mi
thank you very much for the really very quick answer.
It worked!
The problem was that I, at least I think so, under
"file, Prefenrences, Hierarchical Cluster, Two Way Clustering
Then via Analyze, Clustering, Hierarchical
Cluster I clicked "Two Way Clustering" again.
Thanks for the help!
Mi
Mi
