rw1
rw1
Mouse location graph builder
Is there a way to get the mouse location on a graph created using graph builder?
Thanks.
Re: Mouse location graph builder
yes, you can use the cross hair tool (shortcut C, A to get back to Arrow)
to read coordinates off a graph.
If you are writing JSL code to do something, you can add a graphic script:
Graph Builder(
    Size( 522, 450 ),
    Variables( X( :weight ), Y( :height ) ),
    Elements( Points( X, Y, Legend( 6 ) ), Smoother( X, Y, Legend( 7 ) ) ),
        Dispatch(
            "Graph Builder",
            FrameBox,
            {Add Graphics Script(
                2,
                Description( "Script" ),
                If( Is Empty( g_x1 ),
                    g_x1 = [139.41, 134.50, 92.26];
                    g_y1 = [68.63, 52.27, 63.04];
                Drag Line( g_x1, g_y1 );
            ), Grid Line Order( 1 ), Reference Line Order( 3 )}
there are several script functions similar to drag_line that allow the graph to interact with the mouse.  This example is built in to the graph's Customize->plus->samples.  You can drag the endpoints.
Graph Builder(
    Size( 522, 450 ),
        Dispatch(
            "Graph Builder",
            FrameBox,
                2,
rw2
rw2
Thanks - this worked great.
