Hi @YanivD,
It depends how "easy/practical" it is to change your mixing speed.
- If the speed mixing can take any value between 2,5 and 7 m/s, then this factor may be set as a continuous factor.
- If you can change it, but only by "increment", I would recommend to set this factor as a discrete numeric factor and specify the number of levels (and values) you would like to investigate.
Hope this will help you,
Victor GUILLER
Scientific Expertise Engineer
L'Oréal - Data & Analytics
