Mickyboy
Level V
Mixed model - Estimate Only Variance Components with 95% C.I.'s
Hi all,
Is it possible to run a mixed model with random effects, and use the estimate only variance component option and request 95% confidence intervals estimates for the variance components, similar to the output you receive when you select unbounded variance components option and request 95% confidence intervals from the output?
Thanks,
Mick
Mickyboy
Level V
Re: Mixed model - Estimate Only Variance Components with 95% C.I.'s
Hi All,
Thought i had better add a bit more to this, l am running a mixed model with random effects, l have some components with negative variance, so l am using the estimate only variance components, l would like to get 95% confidence intervals in the output if possible, is it possible??? Because l have some negative variance components, l cant use the output from the unbounded variance components option, does anyone have a work around???
Thanks,
Mick.
Mickyboy
Level V
Hi All,
Thanks,
Mick.
