dale_lehman
Time Series Analysis - scripters needed
I am trying to do an ARIMA (1,1,0) analysis on time series data - sample attached.  My table has 450 cities, only 2 are in the sample file.  I want to do the same analysis for each city.  In many JMP platforms, I can hold down the control key and ask for the analysis and it will be done for all the cities in the By box.  However, for setting the ARIMA values, it give me the dialog for each city (450 of them!).  I suspect there is a way to script this so that I only need to specify ARIMA (1,1,0) once and have it applied to each city - but I don't know how to do that.  Can someone help?
Re: Time Series Analysis - scripters needed
Here is a script that I believe will give you what you want
dt = Current Data Table();
ts = Time Series(invisible,
	X( :month ),
	Y( :indexed prices ),
	Forecast Periods( 24 ),
	By( :RegionName of Zillow Data )
// Start final table
dtFinal = New Table( "Final", New Column( "RegionName of Zillow Data", character ) );
// Loop across output creating ARIMA and the Save Columns
For( i = 1, i <= N Items( ts ), i++,
	objt = ts[i] << arima( 1, 1, 0 );
	dtTemp = objt << save columns;
	// Add the By Group name to the data table
	RZD = Word( 2, Report( ts[i] )[Outline Box( 1 )] << get title, "=" );
	dtTemp << New Column( "RegionName of Zillow Data", character, set each value( RZD ) );
	// Add the new table to the Final data table
	dtFinal << concatenate( dtTemp, Append to first table( 1 ) );
	Close( dtTemp, nosave );
6 REPLIES 6
ngambles
The following script will generate an ARIMA(1,1,0) model for "indexed prices" vs "month" for each unique value in "RegionName of Zillow Data."
Time Series(
	X( :month ),
	ARIMA( 1, 1, 0 ),
	By( :RegionName of Zillow Data)
dale_lehman
Thank you - this does what I asked for, but I guess I need one more thing.  I want to save the predictions from these models but the two options - save Prediction Formula or Save Columns both create a new data table for each region (450 of them).  I would like the predictions (with or without standard errors and confidence intervals) to appear in the same data table, but the prediction column should contain the predictions for each of the By group regions.  In other words, one data table, not 450 of them (it can either be one new data table or just columns added to the existing table).
Does this give you what you want?
New Window( "Subset of Comparison data - Time Series of prices",
	V List Box(
		Time Series(
			X( :month ),
			Y( :prices ),
			ARIMA( 1, 1, 0 ),
			Where(
				:RegionName of Zillow Data == "Los Angeles-Long Beach-Anaheim, CA"
		Time Series(
			X( :month ),
			Y( :prices ),
			ARIMA( 1, 1, 0 ),
			by(:RegionName of Zillow Data),
				Dispatch(
					{"Model Comparison"},
					ScrollBox,
					{Background Color( 117 )}
dale_lehman
Same issue - thanks, this does what I asked for.  But I need one more thing - I want to save the predictions from the model all in one table.  If I control-click on the save options, I get 450 tables, one for each Region Name.  Is there a way to get one table with the prediction column linked to each value in Region Name?
	X( :month ),
dale_lehman
jim, you've done it again!  Perfect!
