Created:
Mar 26, 2022 04:31 PM
| Last Modified: Jun 10, 2023 1:49 PM(2857 views)
I'm currently (real time) teaching a class and have encountered a JMP problem I've never seen before. One student's calculator window appears to be missing all of the functions on the left side of the screen. The columns appear and the calculator section of the window appears but there are no functions to choose from and I can't figure out how to get them back. I don't see anything in the preferences for this and I've searched help and the forum and I'm stumped!
Hi Dale, are you referring to the editor window for formula columns? You can move the view slider so the functions screen is effectively collapsed. In that case you would just need to hover the mouse over the area indicated by the red line and drag it back out. Let me know if you are referring to something else. Thanks!
Brilliant! Thanks, I never would have thought about looking there. I don't know when/how this student managed to hide that column but it was easily uncovered once you pointed to where to look.
