GPL12
Mise en tableau des données
Bonjour,
lorsque on fait une mise en tableau des données, peut-on mettre intitule d'une colonne sur deux ligne lorsqu'il est trop long.
Si oui comment
Merci
Re: Mise en tableau des données
I am not aware of any way to do that. Maybe another community member has a work around.
Thierry_S
I'm not sure if I understand properly your problem. By default, JMP wraps long column headers into two lines (no more than 2). The same is true for tables exported to Journals. Hence, I wonder if you are asking about something different?
Please, give us a bit more information; maybe you could share a screenshot of the table you are working with?
Best,
TS
Thierry R. Sornasse
