Stas
Alternative to "Select duplicate rows"
Hey guys,
I'm looking for an alternative to the "Select duplicate rows" function that does not exist in JMP12.
My aim is to delete duplicate rows by column value, with an exception of specific value
For example, if I have this my data table, I want to leave the first substances of column "Color", With an exception that if the "Color" column value is Yellow, leave all these rows and don't delete them.
Eventually I will stay with one fruit of each color, except yellow fruits that will all stay.
FruitColorNumber
AppleRed2
StrawberryRed3
LemonYellow2
BananaYellow4
OrangeOrange5
bananaGreen4
Apricot Orange5
WatermelonGreen4
Re: Alternative to "Select duplicate rows"
Idea from here: Re: Eliminating Duplicate Rows (keeping first duplicate)
I only have JMP15 installed, so I cannot test it this solution will work on JMP12.
dt = New Table("Untitled 2",
	Add Rows(10),
	Compress File When Saved(1),
	New Column("Fruit",
		Character,
		"Nominal",
		Set Values(
			{"Apple", "Strawberry", "Lemon", "Banana", "Orange", "banana", "Apricot",
			"Watermelon", "Kiwi", "Lingonberry"}
		Set Display Width(75)
	New Column("Color",
		Character(16),
		"Nominal",
		Set Values(
			{"Red", "Red", "Yellow", "Yellow", "Orange", "Green", "Orange", "Green",
			"Green", "Red"}
	New Column("Number",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([2, 3, 2, 4, 5, 4, 5, 4, 1, 0])
dt << select where(Col Min(Row(), :color) < Row() & :Color != "Yellow")
//dt << Delete Rows;
Stas
Thanks, I will try it
I tested @jthi elegant solution in JMP 12.2.0 and it worked correctly.
