yummy
Methods to add items (not in excel chart) into a table
Hello~
I use a JMP trial version.
I want to add items (not in excel chart) into a table. Specifically, I want to make new columns just like excel. Somebody help me.. Thx:)
Re: Methods to add items (not in excel chart) into a table
There are multiple ways to add a column. Most obvious way is to go to the Cols menu and choose New Column.
I suspect there is more to your question. Please explain further if this does not answer your question.
As a new user, look under the Help menu and look at the Beginner's Tutorial. That should help you get started.
Dan Obermiller
Hi! Mr. Yeom, this is Jinyoung, Inside Sales rep of JMP Korea. I will call you. Thank you!
