Danijel_V
Method for determining significant effects in experiments
I am trying to analyze around 60 experiments. Each experiment has a lot (around 30 or more) of different continuous and categorical factors (process variables) and for every experiment, various responses (around 10) were measured. Unfortunately, experiments were not made with the design of experiments approach, there is usually a change in just one variable between two experiments (but in the long run, there could be a lot of changes if you compare experiment no. 1 and no. 60).
Is there any useful analysis method for determining the most significant effects on each factor and if possible to also determine the effect size. It would really help me a lot since at the moment I am trying to figure out the most important effects with comparing two experiments at a time. Also, recognition of any patterns in the data would be helpful.
Thank you in advance, Daniel
jules
Re: Method for determining significant effects in experiments
Hi @Danijel_V,
You can use the platform in either way, in fact. If you add a large number of potential predictors, and just one response, you will receive the same kind of output. When you include multiple predictors as well as multiple responses, you get all possible combinations.
@jules
jules
Hi @Danijel_V,
Have you looked into the Response Screening platform in JMP (Analyze > Screening > Response Screening)? At the very least it can help guide your process of detecting the active effects among a large number of comparisons (and the false discovery rate correction will be useful to you, I'm sure). I've included a webinar recording below that also demonstrates the functionality, but as you dig into the platform I suggest you read the documentation I linked above.
@jules
Danijel_V
Thank you for your suggestion, I will certainly look into the response screening more deeply. However, as I see it, response screening is meant mainly for looking on which responses has a certain factor (just 1) effect. I am more interested in the opposite analysis, so which factors have the most influence on a certain response. Is there any similar method than for responses?
jules
Hi @Danijel_V,
@jules
