SDF1
How to write a script to save a currently open report as a PDF
Hi All, I'm not new JMP, but relatively new to JSL. I'm trying to write a script to help automate some data analysis and output of said analysis.
I have a parent JSL script that I'm running that allows users to open files of interest for analysis and then perform a possible sequence of analyses, e.g. distributions, models fits, multivariate, bivariate fits, etc.
I am using a generic function in the script to ask the user to select from the current list of windows (data tables) on which to perform the analysis. The user would select a data table for performing, e.g. a multivariate analysis. I want to have this parent script also have a button script that offers them an option to then save a selected report (again calling the generic select window function). I am having a hard time taking the existing report window, e.g. multivariate analysis, and then sending that to a PDF. I have tried writing code to get the script from the report window and rerun that to send to a journal and save as a PDF, but this fails.
Below is my parent script:
choose_data_table = Function( {},
	list = {};
	For( i = 1, i <= N Table(), i++,
		list[i] = Data Table( i ) << get name
	win = New Window( "Select a data table",
		<<Modal,
		hb = H List Box(
			Panel Box( "Choose a data table",
				dt = List Box( list, max selected( 1 ), chosen = Data Table( (dt << get selected)[1] ) )
New Window( "Data Workup",
	Button Box( "JMP?",
		Web( "C:\Program Files\SAS\JMP\14\Help\index.html" ),
		<<Style( "Underline" ),
		<<Horizontal Alignment( "Right" )
	Text Box(
		"A script to help automate data analysis",
		<<Horizontal Alignment( "center" ),
		<<Set Wrap( 350 ),
		<<Set Font Size( 12 )
	Text Box( "", <<Justify Text( "left" ), <<Set Wrap( 350 ) ),
	H List Box(
		Panel Box( "File Operations",
			V List Box(
				Button Box( "Open file", Open() ),
				Button Box( "Rename data table",
					choose_data_table;
					Wait( 1 );
					User_Input = New Window( "Enter new name",
						<<Modal,
						H List Box( Text Box( "New name:" ), rename = Text Edit Box( "", <<set width( 200 ) ), ),
						Text Box( "Click OK to save" ),
						Button Box( "OK", newname = rename << get text() ),
					chosen << Set Name( newname );
		Panel Box( "Analysis Operations",
			V List Box(
				Button Box( "Select distributions",
					choose_data_table;
					Distribution();
				Button Box( "Graph builder",
					choose_data_table;
					Graph Builder( Variables, Elements( Points( Legend( 1 ) ) ) );
				Button Box( "Fit Y by X",
					choose_data_table;
					Bivariate();
				Button Box( "Fit model",
					choose_data_table;
					Fit Model();
				Button Box( "Multivariate",
					choose_data_table;
					Multivariate();
) << Size Window( 300, 300 );
Here is the script I'm using to try and extract the data to a jrn and save as pdf:
wlist = Get Window List() << Get Window Title();
choose_window = Function( {},
	win = New Window( "Select a Report",
		<<Modal,
		hb = H List Box(
			Panel Box( "Select a report window",
				tcf = List Box( wlist, Max Selected( 1 ), chosen = tcf << Get Selected() )
choose_window;
chosen[1] << SaveAs();
And here's the error I get:
Send Expects Scriptable Object in access or evaluation of 'Send' , chosen[1] << /*###*/SaveAs() /*###*/
I've tried many ways to get around this, but somehow I can't seem to get the JSL script to exectute a function allowing the user to select the report window of choice and have that then saved as a PDF (or PNG, or JPG, etc. -- as desired by the user).
gzmorgan0
Re: How to write a script to save a currently open report as a PDF
Try this:
		<<Modal,
		hb = H List Box(
 chosen;
chosen = choose_window();
w = window(chosen[1]);
w << journal;
//you might need to scale the report to fit in the pdf page
w << Set page setup( margins( 0.5, 1, 0.5, 1 ), scale( .9 ), portrait( 1 ), paper size( "Letter" ) );
w << save pdf("C:/temp/chosen_test.pdf")
gzmorgan0
Try this:
		<<Modal,
		hb = H List Box(
 chosen;
w << journal;
SDF1
Worked great, @gzmorgan0. Thank you!
I did modify the scaling factor based on some discussion in this thread: https://community.jmp.com/t5/Discussions/Scaling-to-fit-to-page-width/td-p/33952
Now, it will adjust the size of the report to fit the page width as needed, which is really nice.
Thanks for the quick help!
