  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Merging two data tables while "intentionally" duplicating records for one against the other table.
heHi All,
I am trying to work on a project. I have two different data tables with uneven rows.
Let say, Table 1 has 19 rows of data with 3 columns and Table 2 has 50 rows of data with 3 columns.
For simplicity, let assume the following:
Table 1
HH_5_ZIP_CODEHH_LATHH_LONG
0101095.2 N95.2 S
0100194.1 N93.2 S
0109265.45 N64.2 S
01610122.1 N120.1 S
Table 2
PD_5_ZIP_CODEPD_LATPD_LONG
01606120.3 N119.2 S
10001119.10 N120.2 S
01510110.20 N123.2 S
What I would like to join both tables (1 & 2) with the destination table being Table 1. In this case, I would like all data from Table 2 to be paired with each of unique record or row in table 1.
For example, the resulting table should look like this.
Table 3
HH_5_ZIP_CODEHH_LATHH_LONGPD_5_ZIP_CODEPD_LATPD_LONGDistance (miles)Time (Hrs)
0101095.2 N95.2 S01606120.3 N119.2 Sto be derivedto be drived
0101095.2 N95.2 S10001119.10 N120.2 S
0101095.2 N95.2 S01510110.20 N123.2 S
0100194.1 N 93.2 S01606120.3 N119.2 S
0100194.1 N93.2 S10001119.10 N120.2 S
0100194.1 N93.2 S01510110.20 N123.2 S
0109265.45 N64.2 S01606120.3 N119.2 S
0109265.45 N64.2 S10001119.10 N120.2 S
0109265.45 N64.2 S01510110.20 N123.2 S
01610122.1 N120.1 S01606120.3 N119.2 S
01610122.1 N120.1 S10001119.10 N120.2 S
01610122.1 N120.1 S01510110.20 N123.2 S
In this file, HH stands for Household and PD stands for Program Destinations (our products). Thus, we want to market programs that are located certain distance away from the homes of our customers per time travel (let say, 1 hours away, 3 hours away and 5 hours away). Using the household zip code or Lat or Long and the Program destinations zip code or Lat & Long I can calculate the total distances and time that any one of our programs is away from the home of any one of our customers. The expectation is that I will come up with a number of programs that are 1 hour away, 3 hours away, or 5 hours away from each of our households.
So, to make this easier, I would like to create one file in which the unique HH Zip Codes with Lat and Long for each household is replicated against each of the program destinations zip code with Lat and Long; such that, I can use a script to calculate the distance and time.
I want the final table to like Table 3 above. Any trick how to do this in JMP 13?
Jenkins Macedo
4 ACCEPTED SOLUTIONS
Byron_JMP
Re: Merging two data tables while "intentionally" duplicating records for one against the
I really hope you weren't like me and resorted to scripting before you found this option in the Tables/Join platform.
Tables>Join>Matching Specification = Cartesian Join
Lol Byron_JMP. Trust me. One thing I like about JMP is my ability to avoid scripting...lol. Less scripting for me means doing more. I thought about using Cartesian Join. Perfect. I will try it and see if it works and keep you posted.
Jenkins Macedo
It worked as you suggested.
Jenkins Macedo
Thanks  Byron_JMP.
Jenkins Macedo
Byron_JMP
Jenkins Macedo
Jenkins Macedo
Thanks  Byron_JMP.
Jenkins Macedo
