BookmarkSubscribeRSS Feed
michaelclarage
Community Trekker
Jan 20, 2017
Merge data by time stamp
I need to merge two different data sets. The first, A, has data collected every 2 minutes. The second, B, has data collected only when a measurement crossed a threshhold.
A-sample
2017-01-21:00:02:00, 1, 2, 3, 4
2017-01-21:00:04:00, 2, 3, 4, 5
2017-01-21:00:06:00, 3, 4, 5, 6
B-sample
2017-01-21:00:02:05, 4500
2017-01-21:00:05:14, 5700
It will be sufficient to put B data into the nearest A row. For example, B-data at 2017-01-21:00:05:14 could be placed into A-row=2017-01-21:00:06:00
I have about 170,000 rows in A; and about 4,000 rows in B.
Thanks
Jun 22, 2012
Solution
Re: Merge data by time stamp
There were a couple of items that did not work with the latest version(s) of JMP in the script that was referenced.  I reworked them, and removed the requirement to run this as a function call.  So all you have to do is to open the 2 data tables and run the script below.  I ran it against your data and it worked well.  I am not sure the results are exactly what you want, but it will give you a data table you can work from.
Clear Symbols();
list_tables = {};
For( i = 1, i <= N Table(), i++,
	Insert Into( list_tables, Data Table( i ) << get name )
);  //sets up names of data tables to pick from
             dt1 = Data Table( list_tables[1] );
dt2 = Data Table( list_tables[2] ); //Reasonable Starting point
             win_tableselect = New Window( "Select Tables",
	<<modal,
	lup_box = Lineup Box( N Col( 2 ),
		Text Box( "Main Table (i.e. SubID List)", <<set font size( 10 ) ),
		Text Box( "Update-With Table (i.e. Tool Data)", <<set font size( 10 ) ),
		c1 = Combo Box(
			list_tables,
			s1 = c1 << getselected;
			dt1 = Data Table( s1 );
			vref1[1] << delete;
			vref1 << append( //Deletes and redraws
                                        				col1 = Col List Box( Data Table( dt1 ), all, maxSelected( 1 ), rt1 = col1 << get selected )
		),   //these parts change the following collistboxes and their fantastic syntax based upon the data table combo box selection
                          		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			s2 = c2 << getselected;
			dt2 = Data Table( s2 );
			vref2[1] << delete;
			vref2 << append(
				col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected )
		),   //see above
                          		vref1 = V List Box(
				Data Table( dt1 ), //still stoopdi
                                        				all,
				maxSelected( 1 ),
		vref2 = V List Box(
		),     //the point of the vrefs is to have something to delete without messing with the lineupbox's proclivity for left-right ordering
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
			rt1 = Char( (col1 << get selected)[1] );
			rt2 = Char( (col2 << get selected)[1] );
		),   //not everyone has the << return result option yet if they're not in 11
                          		Button Box( "Cancel" ),
If( win_tableselect["Button"] == -1,
	Throw( "Canceled by User" )
      dt2 << New Column( "Loc Min", numeric, continuous, formula( Row() ) ); //indexing, basically, to match/update upon
      list_big = Column( dt2, rt2 ) << get values; //creates a vector of values for the following
      dt1 << New Column( "Loc Min",
	numeric,
	continuous,
	formula( Loc Min( Abs( Column( rt1 )[Row()] - list_big ) ) )
);   //simple, but fast.  Very fast.
      dt_join = dt1 << Join(
	With( dt2 ),
	By Matching Columns( :Loc Min = :Loc Min ),
	Drop multiples( 0, 1 ),
	Name( "Include non-matches" )(0, 0),
	Preserve main table order( 1 )
      dt1 << delete columns( "Loc Min" );
dt2 << delete columns( "Loc Min" );  //Removes pesky join column
      list_columns = dt_join << get column names( string );
      For( i = 1, i <= N Items( list_columns ), i++,
	If( Contains( list_columns, "Loc Min" ),
		Column( dt_join, list_columns ) << set selected( 1 )
);  //the joined table will having lingering Loc Min-like columns.  This just hunts them down and removes them.
      dt_join << delete columns;
dt_join << set name( Char( dt1 << get name ) || " & " || Char( dt2 << get name ) );  //Good enough
      Return( dt_join );
8 REPLIES 8
vince_faller
Mar 17, 2015
https://community.jmp.com/t5/Discussions/Join-Question-timestamp-range-kinda-sorta/m-p/20828
This will do it or at least get you on the right track.  And it's stupidly fast.
michaelclarage
Community Trekker
Jan 20, 2017
thanks for the quick response.
I put a "datetime-in-seconds" column in each table, so all data points have a timestamp.
I run the script, it asks me to choose a column in each table, which I do by selecting the "datetime-in-seconds" column in each table.
The end result is just an additional column in dt2 called "Loc Min" which is simply ascending integers 1,2,3,..
Is the function failing, or am I missing something on how to use it?
michaelclarage
Community Trekker
Jan 20, 2017
attaching subsets of the files I am using
Jun 22, 2012
Solution
Clear Symbols();
list_tables = {};
	<<modal,
		c1 = Combo Box(
			list_tables,
			vref1[1] << delete;
                          		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			vref2[1] << delete;
			vref2 << append(
		),   //see above
                          		vref1 = V List Box(
                                        				all,
				maxSelected( 1 ),
		vref2 = V List Box(
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
	numeric,
	continuous,
	With( dt2 ),
      Return( dt_join );
michaelclarage
Community Trekker
Jan 20, 2017
Jim,
Thanks so much. I think we are all set now.
gzhou
New Contributor
Feb 10, 2019
How could you modify this JMP script to allow it join two data tables by matching two different variable?
For example: In the data set below, I would like to match by Experiment # and then match by the local min of the timestamp to join values of data table 2 onto data table 1 such that values of data table 2 is in one row of the nearest timestamp in data table 1 with the correct experiment #.
A-sample
Experiment 1, 2017-01-21:00:02:00, 1, 2, 3, 4
Experiment 1, 2017-01-21:00:04:00, 2, 3, 4, 5
Experiment 2, 2017-01-21:00:06:00, 3, 4, 5, 6
B-sample
Experiment 1, 2017-01-21:00:02:05, 4500
Experiment 2, 2017-01-21:00:05:14, 5700
Any assistance would be helpful!
Thanks
Jun 22, 2012
Here is a modification of the script that I believe will give you what you want.  Now, it hasn't been fully tested, since you did not provide sample data tables, but I believe it should work, if the variable you are placing your experiment number into is called "Experiment".
Clear Symbols();
list_tables = {};
	<<modal,
		c1 = Combo Box(
			list_tables,
			vref1[1] << delete;
		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			vref2[1] << delete;
			vref2 << append( col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected ) );
		),   //see above
		vref1 = V List Box(
				all,
				maxSelected( 1 ),
		vref2 = V List Box( col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected ) ),     //the point of the vrefs is to have something to delete without messing with the lineupbox's proclivity for left-right ordering
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
//dt1=data table("AMPERE-concat-cleaned-subset (2)");
//dt2=data table("USGA data 2010 subset (2)");
//list_big = Column( dt2, rt2 ) << get values; //creates a vector of values for the following
//rt2 = column( dt2, "date-time-in-seconds");
dt3 = dt2 << subset( selected rows( 0 ), columns( {"Experiment", "loc min", rt2} ) );
// Find out the number of experiments
Current Data Table( dt3 );
Summarize( dt3, experiments = by( :Experiment ) );
If( Column( dt3, "Experiment" ) << get data type == "Numeric",
	For( i = 1, i <= N Items( experiments ), i++,
		experiments[i] = Num( experiments[i] )
	dt3 << New Column( "__exp__" || Char( experiments[i] ), set each value( . ) );
	theRows = dt3 << get rows where( :Experiment == experiments[i] );
	For( k = 1, k <= N Rows( theRows ), k++,
		Column( dt3, N Cols( dt3 ) )[theRows[k]] = rt2[theRows[k]]
dt3 << delete columns( 1, 2, 3 );
list_big = dt3 << get as matrix;
Close( dt3, nosave );
	numeric,
	continuous,
	formula(
		whichExp = Loc( experiments, :Experiment );
		Loc Min( Abs( Column( rt1 )[Row()] - list_big[0, whichExp] ) );
	With( dt2 ),
Return( dt_join );
gzhou
New Contributor
Feb 10, 2019
Thank you so much txnelson! I will test it out.
-gzhou
