OK, I'm sorry to hear that but not surprised. Until the vendor that we use fully supports XLSB, the only recourse will be to open the file in Excel and save as XLSX or XLSM.
You don't mention what version of JMP you are using, or on what OS. If it is a recent version on Windows, try using the "All Files" filter on File Open, point it to the XLSB and see if it will open. JMP uses a 3rd party engine to open these files. It didn't used to open XLSB, but can handle some cases of it now.
Brian
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '110583' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '110583') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '110583') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
