michaelclarage
Merge data by time stamp
I need to merge two different data sets. The first, A, has data collected every 2 minutes. The second, B, has data collected only when a measurement crossed a threshhold.
A-sample
2017-01-21:00:02:00, 1, 2, 3, 4
2017-01-21:00:04:00, 2, 3, 4, 5
2017-01-21:00:06:00, 3, 4, 5, 6
B-sample
2017-01-21:00:02:05, 4500
2017-01-21:00:05:14, 5700
It will be sufficient to put B data into the nearest A row. For example, B-data at 2017-01-21:00:05:14 could be placed into A-row=2017-01-21:00:06:00
I have about 170,000 rows in A; and about 4,000 rows in B.
Thanks
Re: Merge data by time stamp
There were a couple of items that did not work with the latest version(s) of JMP in the script that was referenced.  I reworked them, and removed the requirement to run this as a function call.  So all you have to do is to open the 2 data tables and run the script below.  I ran it against your data and it worked well.  I am not sure the results are exactly what you want, but it will give you a data table you can work from.
Clear Symbols();
list_tables = {};
For( i = 1, i <= N Table(), i++,
	Insert Into( list_tables, Data Table( i ) << get name )
);  //sets up names of data tables to pick from
             dt1 = Data Table( list_tables[1] );
dt2 = Data Table( list_tables[2] ); //Reasonable Starting point
             win_tableselect = New Window( "Select Tables",
	<<modal,
	lup_box = Lineup Box( N Col( 2 ),
		Text Box( "Main Table (i.e. SubID List)", <<set font size( 10 ) ),
		Text Box( "Update-With Table (i.e. Tool Data)", <<set font size( 10 ) ),
		c1 = Combo Box(
			list_tables,
			s1 = c1 << getselected;
			dt1 = Data Table( s1 );
			vref1[1] << delete;
			vref1 << append( //Deletes and redraws
                                        				col1 = Col List Box( Data Table( dt1 ), all, maxSelected( 1 ), rt1 = col1 << get selected )
		),   //these parts change the following collistboxes and their fantastic syntax based upon the data table combo box selection
                          		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			s2 = c2 << getselected;
			dt2 = Data Table( s2 );
			vref2[1] << delete;
			vref2 << append(
				col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected )
		),   //see above
                          		vref1 = V List Box(
				Data Table( dt1 ), //still stoopdi
                                        				all,
				maxSelected( 1 ),
		vref2 = V List Box(
		),     //the point of the vrefs is to have something to delete without messing with the lineupbox's proclivity for left-right ordering
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
			rt1 = Char( (col1 << get selected)[1] );
			rt2 = Char( (col2 << get selected)[1] );
		),   //not everyone has the << return result option yet if they're not in 11
                          		Button Box( "Cancel" ),
If( win_tableselect["Button"] == -1,
	Throw( "Canceled by User" )
      dt2 << New Column( "Loc Min", numeric, continuous, formula( Row() ) ); //indexing, basically, to match/update upon
      list_big = Column( dt2, rt2 ) << get values; //creates a vector of values for the following
      dt1 << New Column( "Loc Min",
	numeric,
	continuous,
	formula( Loc Min( Abs( Column( rt1 )[Row()] - list_big ) ) )
);   //simple, but fast.  Very fast.
      dt_join = dt1 << Join(
	With( dt2 ),
	By Matching Columns( :Loc Min = :Loc Min ),
	Drop multiples( 0, 1 ),
	Name( "Include non-matches" )(0, 0),
	Preserve main table order( 1 )
      dt1 << delete columns( "Loc Min" );
dt2 << delete columns( "Loc Min" );  //Removes pesky join column
      list_columns = dt_join << get column names( string );
      For( i = 1, i <= N Items( list_columns ), i++,
	If( Contains( list_columns, "Loc Min" ),
		Column( dt_join, list_columns ) << set selected( 1 )
);  //the joined table will having lingering Loc Min-like columns.  This just hunts them down and removes them.
      dt_join << delete columns;
dt_join << set name( Char( dt1 << get name ) || " & " || Char( dt2 << get name ) );  //Good enough
      Return( dt_join );
8 REPLIES 8
vince_faller
https://community.jmp.com/t5/Discussions/Join-Question-timestamp-range-kinda-sorta/m-p/20828
This will do it or at least get you on the right track.  And it's stupidly fast.
Vince Faller - Predictum
michaelclarage
thanks for the quick response.
I put a "datetime-in-seconds" column in each table, so all data points have a timestamp.
I run the script, it asks me to choose a column in each table, which I do by selecting the "datetime-in-seconds" column in each table.
The end result is just an additional column in dt2 called "Loc Min" which is simply ascending integers 1,2,3,..
Is the function failing, or am I missing something on how to use it?
michaelclarage
attaching subsets of the files I am using
Clear Symbols();
list_tables = {};
	<<modal,
		c1 = Combo Box(
			list_tables,
			vref1[1] << delete;
                          		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			vref2[1] << delete;
			vref2 << append(
		),   //see above
                          		vref1 = V List Box(
                                        				all,
				maxSelected( 1 ),
		vref2 = V List Box(
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
	numeric,
	continuous,
	With( dt2 ),
      Return( dt_join );
michaelclarage
Jim,
Thanks so much. I think we are all set now.
gzhou
How could you modify this JMP script to allow it join two data tables by matching two different variable?
For example: In the data set below, I would like to match by Experiment # and then match by the local min of the timestamp to join values of data table 2 onto data table 1 such that values of data table 2 is in one row of the nearest timestamp in data table 1 with the correct experiment #.
A-sample
Experiment 1, 2017-01-21:00:02:00, 1, 2, 3, 4
Experiment 1, 2017-01-21:00:04:00, 2, 3, 4, 5
Experiment 2, 2017-01-21:00:06:00, 3, 4, 5, 6
B-sample
Experiment 1, 2017-01-21:00:02:05, 4500
Experiment 2, 2017-01-21:00:05:14, 5700
Any assistance would be helpful!
Thanks
Here is a modification of the script that I believe will give you what you want.  Now, it hasn't been fully tested, since you did not provide sample data tables, but I believe it should work, if the variable you are placing your experiment number into is called "Experiment".
Clear Symbols();
list_tables = {};
	<<modal,
		c1 = Combo Box(
			list_tables,
			vref1[1] << delete;
		c2 = Combo Box(
			list_tables,
			<<set( 2 ),
			vref2[1] << delete;
			vref2 << append( col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected ) );
		),   //see above
		vref1 = V List Box(
				all,
				maxSelected( 1 ),
		vref2 = V List Box( col2 = Col List Box( Data Table( dt2 ), all, maxSelected( 1 ), rt2 = col2 << get selected ) ),     //the point of the vrefs is to have something to delete without messing with the lineupbox's proclivity for left-right ordering
	Text Box( "" ),
	H List Box(
		Button Box( "Ok",
//dt1=data table("AMPERE-concat-cleaned-subset (2)");
//dt2=data table("USGA data 2010 subset (2)");
//list_big = Column( dt2, rt2 ) << get values; //creates a vector of values for the following
//rt2 = column( dt2, "date-time-in-seconds");
dt3 = dt2 << subset( selected rows( 0 ), columns( {"Experiment", "loc min", rt2} ) );
// Find out the number of experiments
Current Data Table( dt3 );
Summarize( dt3, experiments = by( :Experiment ) );
If( Column( dt3, "Experiment" ) << get data type == "Numeric",
	For( i = 1, i <= N Items( experiments ), i++,
		experiments[i] = Num( experiments[i] )
	dt3 << New Column( "__exp__" || Char( experiments[i] ), set each value( . ) );
	theRows = dt3 << get rows where( :Experiment == experiments[i] );
	For( k = 1, k <= N Rows( theRows ), k++,
		Column( dt3, N Cols( dt3 ) )[theRows[k]] = rt2[theRows[k]]
dt3 << delete columns( 1, 2, 3 );
list_big = dt3 << get as matrix;
Close( dt3, nosave );
	numeric,
	continuous,
	formula(
		whichExp = Loc( experiments, :Experiment );
		Loc Min( Abs( Column( rt1 )[Row()] - list_big[0, whichExp] ) );
	With( dt2 ),
Return( dt_join );
gzhou
Thank you so much txnelson! I will test it out.
-gzhou
