Hello
I would like to find test names that continue "pcie0" sometimes in lower or upper format
I understand I should use Match case ( 0 )
I have added it to my script but received error
can you check what I should change in my script?
Column(dt, "PARAMETR") << Set Each Value( If( Contains(( :TEST_NAME,"pcie0")), Match case( 0 ),"PCIE0",:PARAMETR));
