skyzvoir0001
Marker
How to set the legend in age=14 to a circle with no fill thru scripting?
Re: Marker
Use a script like this to set the marker you prefer for your desired rows:
rows = dt << Select Where( :Age == 14 );
rows << Markers( 8 );
Then when you make any visuals, those markers will be applied.  Or if you prefer not to do through scripting you can do this:
1. Right click on the value in your data table you wish to set markers for
2. Select Matching Cells
3. From Row menu choose Markers and pick your marker from there
pmroz
Re: Marker
If you click the red triangle and select save script you will see the necessary JSL commands to change the marker.  Here's an example:
dt = open("$sample_data/Car Physical Data.jmp");
dt << Graph Builder(
	Variables( X( :Displacement ), Y( :Weight ), Overlay( :Country ) ),
	Elements( Points( X, Y, Legend( 3 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				3,
				Properties( 2, {Marker( "Circle" )}, Item ID( "USA", 1 ) )
Re: Marker
skyzvoir0001
Re: Marker
Thanks! The markers on the plot changed. However, why didnt it change on the legend part?
skyzvoir0001
Re: Marker
Here is what i meant
Bivariate(
	Y( :height ),
	X( :weight ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				age,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
ab = Data Table( "Big Class" );
ab << Select Where( :Age == 12 ) << Colors( 1 ) << Markers( 8 ) << clear select;
The row legend where age=12 did not change however the markers on the plot did.
pmroz
Re: Marker
You can set individual markers manually by double-clicking on the legend.  In the popup window right click on the marker of interest and select Marker > (click on desired marker here).
skyzvoir0001
Re: Marker
Hey thanks for the reply! But is there a way to do it thru scripting? Im trying to make a script dynamically which copies the plots directly to a powerpoint and I’ve been stuck on how to change the legend part.
pmroz
Re: Marker
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				3,
skyzvoir0001
Re: Marker
Thank you very much!
