Looping through rows of a column to find the overall count
Trying to find the number of counts of current entry in a column. The below function works but seems to be slow. Any suggestions to improve the script run time?
JMP14, JMP16
<For each row(Print(Col Number( :ColName, :ColName )))>
My proposal: I think initially constructing Associative Array by adding the entries from the :ColName as "Key" and increasing the value (Value++) when duplicate entry i.e. duplicate Key or if it's a new entry, adding a separate Key with value set to 1 would be a better way. Then you can just loop through rows to find the number of "Value" for it.
Re: Looping through rows of a column to find the overall count
The simplest solution is to simply merge the summary table into the original table using the
     Tables => Update
platform
names default to here(1);
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
dt_summary = dt << Summary( invisible, Group( :height ), Freq( "None" ), Weight( "None" ) );
dt_summary:N Rows << set name("height_qty");
dt << Update(
	With( dt_summary ),
	Match Columns( :height = :height )
close( dt_summary, nosave );
Is there a specific reason why you wish to loop over the rows? You could most likely use Tabulate or Summary table to perform similar task
Summary + Stack table
Here are a couple of ways to do what I believe you want.
dt = Current Data Table();
Summarize( dt, items = by( :colName ) );
countOfUniqueValues = N Items( items );
// or
countOfUniqueValues = N Items( Associative Array( :colName ) << get keys );
I am summarizing (dt_summary) the bigger data table (dt) which gives me the number of rows for each particular entry in the column: ColName.
dt_summary = dt << Summary( Group( :ColName ), Freq( "None" ), Weight( "None" ) );
Now I want to iterate through the original table (dt) rows and get the number of rows from summary table for current row to check if above 10 (occurrences).
Summary Table (group by height):
So let's say I am on first row, the height is 59 and occurrences are 2, I want to populate that information in the current data table (dt) in a new column (height_qty).
     Tables => Update
platform
dt =
dt << Update(
	With( dt_summary ),
Really appreciate your quick help, Jim. It worked as expected and the run time reduced to ~2 seconds from almost a minute.
