Neo
Neo
How to change Color Theme for a given chart (Graph Builder) via JSL without changing it globally via preferences?
I do not want to change the Color Theme in my JMP preferences as mentioned here https://www.jmp.com/support/help/en/17.2/index.shtml#page/jmp/create-color-themes-in-graphs.shtml. Instead I would like to plot a chart with a chosen color theme e.g.  use "Strong and Pastel Mix" in place of "JMP default".
How to do this in JSL?
When it's too good to be true, it's neither
Re: How to change Color Theme for a given chart (Graph Builder) via JSL without changing it globally via preferences?
Search Scripting Index for Color Theme and select Graph Builder from left
