ALopez
Looping over a List and concatenating a string
Hi,  I have a "List" and I want to concatenate each item with the suffix "_2020" and Insert it into a new list.
I have tried this code but I am missing something.  I will appreciate your input.
Thanks!
FullNames ={};
todaysList = {"August", "July", "June", "May"};
TotalMs = N Items (todaysList);
For (i = todaysList, i <= TotalMs, i++,
	newName = (todaysList[i] ||"_2020");
	Insert Into (FullNames, newName),
Re: Looping over a List and concatenating a string
Your For() loop starting index was invalid.  Here is your code with a slight modification to make it work
FullNames ={};
For (i = 1, i <= TotalMs, i++,
	newName = todaysList[i] ||"_2020";
FullNames ={};
ALopez
Yes, I can see my Index error, darn so obvious (after you mentioned).  What I still do not understand is the lack of parenthesis around the concatenation expression.  I will do some more reading.
Thank you very much.
Best regards,
Alfredo
Searching the Concat function in the JMP Scripting Index (Help->Scripting Index), it can be seen that use of the double bar operator doesn't require parentheses.  In case you weren't aware of it, the Scripting Index is a very powerful resource.
