sitiamy
How to save data table in .zip format
Hi experts,
Is there a way to save or compress the current data table as in .zip format using JSL scripting?
Thank you
Re: How to save data table in .zip format
Here is a discussion post on this topic that you may find useful: Compress a Folder into a Zip File
sitiamy
Hi there,
Work like a charm.
Thank you for pointing the post.
Perfect, glad to hear it.
Craige_Hales
On the data table's red triangle menu, "compress table when saved". The compression is internal and will automatically decompress when the table is opened, and re-compress if it is saved again.
Craige
