shampton82
Loop through "SendToReport" element in process screener
Hey everyone,
I am trying to loop though a Proces Screener script that makes the "Charts as selected" report element.  I need it to be flexible as the number of Reponses in the screener can change over time.  So I tried putting in this loop to change the axis format of the charts but alas it does not work.
		Dispatch( {}, "", TableBox, {Sort By Column( 2, 1 )} ),
		Dispatch( {}, "Charts as Selected", OutlineBox, {Close( 1 )} ),
		For( i = 1, i <= 422, i++,
			Dispatch(
				{"Charts as Selected"},
				"1",
				ScaleBox(i),
				{Format( "m/d/y", 10 ), Min( 3784397666.7875 ), Max( 3787415686.74375 ), Interval( "Week" ), Inc( 1 ), Minor Ticks( 6 ),
				Label Row( {Label Orientation( "Perpendicular" ), Show Major Grid( 1 )} )}
			Dispatch( {"Charts as Selected"}, "ProcessScreening Graph As Selected", FrameBox( i ), {Frame Size( 602, 255 )} ),
this is a section of code that show the repetition I am trying to loop over
		Dispatch({"Charts as Selected"},
			"1",
			ScaleBox,
			{Min( 3784397666.7875 ), Max( 3787415686.74375 ), Interval( "Week" ), Inc( 1 ), Minor Ticks( 6 ),
		Dispatch( {"Charts as Selected"}, "ProcessScreening Graph As Selected", FrameBox, {Frame Size( 602, 255 )} ),
		Dispatch(
			"1",
			ScaleBox( 2 ),
Dispatch( {"Charts as Selected"}, "ProcessScreening Graph As Selected", FrameBox( 2 ), {Frame Size( 602, 255 )} ),
Any guidance would be appreciated!
Steve
Re: Loop through "SendToReport" element in process screener
Without knowing what you are really trying do, I would suggest that you modify them after selections have been done by getting references to those axis (scaleboxes) using << XPath and then modifying that list by sending message(s) to that list.
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
obj = dt << Process Screening(
	Process Variables(Column Group("Processes")),
	Grouping(:SITE),
	Control Chart Type("Indiv and MR"),
	Show Charts as Selected(1),
	RowStates([0 1, 171 1, 245 1])
scs = Report(obj) << XPath("//ScaleBox");
xaxis_idx = 2::N Items(scs)::3;
scs[xaxis_idx] << Min(-100) << Max(400) << Inc(100) << Inc(100) << Minor Tics(2);
	Grouping(:SITE),
shampton82
Thanks @jthi !!
That worked great.  I ended up add in my stuff as so:
scs = Report(psobj) << XPath("//ScaleBox");
xaxis_idx = 2::N Items(cnames)::3;
scs[xaxis_idx] << Min(3784397666.7875) << Max(3787415686.74375) << Interval( "Week" ) << Inc( 1 ) << Minor Ticks( 6 )<<Label Row( {Label Orientation( "Perpendicular" )})<<Show Major Grid( 1 );
Quick question, how did you know to use Scalebox?  When I looked at the properties of the Process Screener I didn't see Scalebox called out.  When I clicked on the axis of the charts it said Axisbox.
This part told me that I could (at least try) to use ScaleBox
You could have also used AxisBox (it might be that in earlier JMP versions you would have had to use axisbox). Note that it has different start index
	Grouping(:SITE),
scs = Report(obj) << XPath("//AxisBox");
xaxis_idx = 3::N Items(scs)::3;
scs[xaxis_idx] << Min(-100) << Max(400) << Inc(100) << Inc(100) << Minor Ticks(2);
shampton82
Perfect, thanks!!
