Phil_Brown
ListBox size
Is there a way to retrieve the set the size of a TableBox? There is a message for GETTING the size but it doesn't appear there's a way to SET size. Maybe I'm missing something?
The display box 'TableBox' does not recognize the message 'set size'; perhaps you mean one of these:  <<Get Size <<Set Window Size <<Get Window Size <<User Resizable <<Reset Style <<Set Shade Cells <<Set Shade Headings <<Set Scrollable <<Set Selectable Rows <<Set Selected Rows <<Get As Matrix <<Set Click Sort <<Paste <<Select <<Inval Size <<Selectable <<Set Report Title <<Set Window Title <<Delete <<Show Properties <<Restore Window Size <<Get Text <<Get Script <<Get Picture <<Save Text <<Save RTF <<Save Picture <<Save Capture <<Set Window ID <<Get Content Size <<Set Content Size <<Size Window <<Set Window Title <<Set Print Headers <<Set Print Footers <<Set Page Setup <<Get Page Setup <<GetOffset <<SetNotStretchable <<Get Min Size <<Set Min Size <<Get Max Size <<Set Max Size <<Set Auto Stretching <<Get Row States <<Set Width <<Set Height <<Set Property <<Set Property.
PDB
Re: ListBox size
There is no Set Size message for a Table Box. However, you can set the size for the columns within the Table Box.
In the example below, I create a Table Box that contains two String Col Boxes. The sizes of the Table Box and String Col Boxes are shown before and after changing the size of the columns.
New Window( "test",
	tb = Table Box(
		scb1 = String Col Box( "a", {"x", "y", "z"} ),
		scb2 = String Col Box( "b", {"1", "2", "3"} )
Write( "before:" );
Show( tb << Get Size(), scb1 << Get Size(), scb2 << Get Size() );
scb1 << Set Width( 300 );
scb2 << Set Width( 400 );
Wait( 0 ); // Wait for display to update so that get size returns latest size
Write( "\!N\!Nafter:" );
Below is the resulting log. Notice how the size of the Table Box is a few pixels larger than the sum of the sizes of the columns it contains.
before:
tb << Get Size() = {39, 74};
scb1 << Get Size() = {18, 72};
scb2 << Get Size() = {20, 72};
after:
tb << Get Size() = {701, 74};
scb1 << Get Size() = {300, 72};
scb2 << Get Size() = {400, 72};
Justin
Phil_Brown
Re: ListBox size
PDB
Re: ListBox size
New Window( "test",
	tb = Table Box(
Write( "before:" );
before:
after:
Justin
Re: ListBox size
How to change width of lost box?
Re: ListBox size
got it
