WHTseng
How to script a dialog box for multiple file?
Hi JMP users,
I am looking for a method to select many files, and then point them into different variables.
I don’t think the function Pick File is suitable because I have to set the variables to the data tables one by one.
The first thing crossed my mind is file select dialog(like the picture below), I can input the path or select the files from icon.
And point every file to the corresponding variable in script code, no manual selection is needed.
Do you have idea how to make it with JMP script?
Thank you for all the supports.
Re: How to script a dialog box for multiple file?
I would use Pick Directory()
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	{"JMP Files|jmp;jsl;jrn", "All Files|*"},
	1,
	0,
	"newJmpFile.jmp"
and then the Files in Directory()
Files In Directory( "$HOME" );
to get started with what you want to do.
Look to the Scripting Index for the examples and definitions
     Help==>Scripting Index
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	1,
	0,
	"newJmpFile.jmp"
WHTseng
Hi txnelson,
Thank you for the idea.
Files in Directory() indeed gives me the file list so that I can do further selection among them.
