My experience with Time Series in JMP is relatively short, so forgive me if this question seems basic.
Forecasting in the covid environment can be challenging at times due to lockdowns in various parts of the country. I’m trying to run the Linear (Holt) Exponential Smoothing for +2K locations based on most recent trends using Time Series – Autocorrelation by location. The results give me a time series by location but when I hold the shift +ctrl keys down, select simple smoothing, select linear exponential smoothing I have to set the predictive interval “0.95” and Constraints “Zero to One” for each location (+2K times).
Question: Is there a way to set this prompt once for all +2K locations?
Product Used: JMP (not JMP Pro)
Thank you
