mostarr
Do JMP DT Columns with Special Characters in them (/, ., etc.) Need their Special Characters Escaped in Formulas?
I have a column with a backslash in the title, do I need to either escape it or put the column's name in quotes when referencing it in a formula in a JSL script?
Mike
Re: Do JMP DT Columns with Special Characters in them (/, ., etc.) Need their Special Characters Escaped in Formulas?
Not completely sure but links these will most likely have answers for you:
Utility Functions - Name(String) (will be depracated)
JSL Syntax Rules - Names
I think same rules are applied for column names
This seems to work fine:
dt = New Table("Untitled 2",
	Add Rows(2),
	Compress File When Saved(1),
	New Column("Column\",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([1, 2])
Show(Col Sum(:Column\));
I wouldn't feel comfortable referencing columns like that even if it would work and would use some other way (AsColumn(), Column(), :"column name"n depending on the case).
