I am exporting graphs that have a line break in the graph title, but the line break is not applied to my PPT slide title. Is there a way to fix this in JMP, or do I just chalk it up to another unfortunate JMP-to-PPT mismatch?
Graph builder graph title :
Title Line 1
Title Line 2
When exported to PPT:
Title Line 1Title Line 2
Hi @Raybob ,
I'm actually struggling to figure out how to add a line break in the title!
I suggest that you ask technical support about this one (email: [email protected]).
Regards,
Phil
I built one using JSL <<setTitle and I see the same issue. I'm pretty sure the newline was removed when the file was being saved. If I manually re-insert it in the ppt file, LibreOffice Impress shows the newline. Can't say what PP might do.
