Jackie_
How to assign Multiple values to SQL variable
I'm trying to input multiple values from the jmp file into SQL variable. Something doesn't seem to work
User will input the following file and the columns values are stored in the variable specVal .
I declared @ SPEC = ^specVal^ (Contains 3 values ) in SQL
Something doesn't seem to be correct.
Clear Globals();
Clear Log();
specVal = "";
NW = New Window( "DLT Data",
	<<Modal(),
	<<Return Result,
	Text Box( "" ),
	Spacer Box( Size( 20, 10 ) ),
	Lineup Box( N Col( 3 ), Text Box( "Lot id" ), Spacer Box( Size( 20, 20 ) ), lotnum = Text Edit Box( "F141", <<set width( 100 ) ) ),
	Panel Box( , Button Box( "Select file", dt = Open() ) ),
	H List Box(
		Text Box( "Start data" ),
		Start_date = Text Edit Box( "1/1/2022", <<set width( 60 ) )
	Lineup Box( N Col( 2 ), Text Box( "End data" ), End_date = Text Edit Box( "", <<set width( 60 ) ) ),
	Panel Box( ,
		H List Box(
			Button Box( "OK",
				specVal = :Column 1 << Get Values;
				specVal1 = Start_date << get text();
				specVal2 = End_date << get text();
			Button Box( "Cancel" )
	<<Size Window( 250, 300 )
	//Button Box( "OK", specVal = specCB << get text())
If( specVal != "",
	(ODBC = Create Database Connection( "DSN=xxx;;UID=xxx;PWD=;APP=JMP;WSID=xxx;DATABASE=xxx;" ) ;
	SQL =
	Eval Insert(
DECLARE @SPEC1 VARCHAR (50)
SET @SPEC1 = '^specVal^'
SELECT t1.[vcLotCode]
FROM [dbo].[vSMTDatat]  t1
WHERE  (  (  (  ( t1.[vcLotCode] IN  ( @SPEC1 )  )  )  ) ;" // Input from the user
	DT = Execute SQL( ODBC, SQL, "DLT Data" ) << Maximize window ;
	Close Database Connection( ODBC ) ;
Thanks
pmroz
Re: How to assign Multiple values to SQL variable
@jthi is on the right track.  Print out the SQL code and try running it manually in SQL server.
I would point a variable at the data table to avoid scoping errors.
This is what your SQL code looks like:
SET @SPEC1 = '{"F14CDCE", "F141CDC5", "F141CDLU"}'
Will that work in SQL Server?  In Oracle I create IN lists and substitute them like this:
// Point dt to your table of values
dt = New Table( "SpecValues", Add Rows( 3 ),
	New Column( "Column 1", Character, "Nominal",
		Set Values( {"F14CDCE", "F141CDC5", "F141CDLU"} ) )
// Relevant section to create IN list
			Button Box( "OK",
				specVal = dt:Column 1 << Get Values;
				spec_in_list = "'" || concat items(specval, "', '") || "'";
// SQL Code
	SQL = Eval Insert(
"SELECT t1.[vcLotCode]
  WHERE  (  (  (  ( t1.[vcLotCode] IN  ( ^spec_in_list^ )  )  )  ) ;" // Input from the user
	write(sql);
Jackie_
@txnelson
Any suggestion?
I would suggest printing the SQL-query to see that it is being built as you want it to be built.
pmroz
			Button Box( "OK",
// SQL Code
	SQL = Eval Insert(
	write(sql);
Jackie_
I really appreciate this. Thanks a LOT
