When one uses JMP Platforms in a formula, just as when you use them interactively or in a script, the input to the Platform has to be columns from a data table. Therefore, you can not reference the input by creating an input matrix. So what I did to make your formula work, is to take advantage of being able to Exclude rows from the data table and when the platform is run, it will ignore those rows. Here is the formula, and the output it creates:
If( Row() >= 10,
currentRow = Row();
dt << clear rowstates;
dt << select where( Row() <= currentRow - 10 | Row() > currentRow );
excludeRows = dt << get selected rows;
dt << hide and exclude;
mv = dt << Multivariate(
invisible,
Y( :TimeStep, :F ),
Estimation Method( "Row-wise" ),
Matrix Format( "Square" ),
Scatterplot Matrix( Density Ellipses( 0 ), Shaded Ellipses( 0 ) ),
Kendall's τ( 1 )
tau = (Report( mv )["Nonparametric: Kendall's τ"][Number Col Box( 1 )] << get)[1];
mv << close window;
If( Row() == N Rows( dt ),
tau;
The data table
I suggest that once you have created the column, and it has run the formula, that you go to the Col Info dialog, and remove the formula. It will leave the static values, but will not keep rerunning the formula over and over....it isn't the fastest
