BookmarkSubscribeRSS Feed
Danijel_V
Jul 7, 2017
K fold Cross-Validation in DSD
I have a quick question. If you analyse DSD the literature (instructions in JMP) proposes two methods. The first is Fit defintive screening and the second is Forward stepwise regression, with Stopping rule: min AICc and rules: Combine. I was thinking about using k fold cross validation, if Forward stepwise regression turns out to give the better model than the Fit definitive screening. But does that even make sense with DSD? DSD is a foldover design and I think that doing model on only, for example, 3/4 of the runs, wouldn't make sense. Am I right or wrong?
Thank you for your answer.
Danijel
markbailey
Jun 23, 2011
Solution
Re: K fold Cross-Validation in DSD
First of all, there is no method that I know of that is guaranteed to find the best model. (That is, if you can even define "best.")
Second of all, this case is a screening experiment in which economy is one of the most desirable characteristics of the design. That economy means that a DSD is a small design, compared to the minimum number of runs for the linear model with only main effects. Holding out any data will affect the estimation and testing (power). You might be able to compensate by add extra runs, but then you might just as well use custom design.
Third of all, K-fold cross-validation is useful with small data sets but the analysis and unique set of benefits of the DSD depend on the unique structure of this design. The omission of each fold in turn would destroy this structure and compromise the fitting.
Would it work? Most likely. Would it work well? Not likely.
It can't hurt to try it, instead of thinking about it. Simulation would be a valuable approach. JMP makes that approach easy.
markbailey
Jun 23, 2011
Solution
Danijel_V
Jul 7, 2017
Thank you, I was also thinking similarly.
