Dennisbur
Journal in 2 or 3 columns
Hello guys,
I calculated 2 tables HOT_per_skew and COLD_per_skew
when I added these 2 tables to the Journal, I got the vertical position.
My question is, how can I present these 2 tables in a Horizontal position by JSL script?
HOT_per_skew << Journal ( ) << Close Window ( );
COLD_per_skew<< Journal ( ) << Close Window ( );
Re: Journal in 2 or 3 columns
I think you can just wrap them in H List Box (Or Lineup Box(N Col(2))
dt1 = open("$SAMPLE_DATA/Big Class.jmp");
dt2 = open("$SAMPLE_DATA/Big Class Families.jmp");
Current Journal();
H List Box(dt1 << get as report, dt2 << get as report) << journal;
Close(dt1, nosave);
Close(dt2, nosave);
You can use Text boxes
Current Journal();
Close(dt1, nosave);
Close(dt2, nosave);
Text Box("My text") << Journal;
but I would suggest you build your report in new window and then turn it into journal when it is ready (this can be a bit difficult with reports)
nw = New Window("",
	V List Box(
		Text Box("My Text")
	H List Box(
nw << journal;
nw << close window
https://www.jmp.com/support/help/en/17.2/#page/jmp/display-trees.shtml#
Current Journal();
Close(dt1, nosave);
Close(dt2, nosave);
Dennisbur
Thank you!
BTW also, do I have the option to add text in the Journal by script JSL?
Current Journal();
Close(dt1, nosave);
Close(dt2, nosave);
nw = New Window("",
	V List Box(
		Text Box("My Text")
	H List Box(
nw << journal;
nw << close window
