robot
JSON Import Wizard with Pandas Values and Headers
I am trying to import a JSON file as a Data Table, and having difficulty finding the correct settings in the JSON Wizard.  Does anyone know the correct settings to use?  I am using JMP 18.0.1.
Example JSON
    "data": {
        "index": [
            0,
            1,
            2,
            3,
            4
        "columns": [
            "device_name",
            "num",
            "voltage_measure_V",
            "current_source_applied_A",
            "in_compliance"
        "data": [
                "DEVICE_A",
                1,
                0.35,
                0.03,
                false
                "DEVICE_B",
                2,
                0.40,
                0.52,
                false
                "DEVICE_C",
                3,
                0.45,
                0.21,
                false
                "DEVICE_D",
                4,
                0.50,
                0.53,
                false
                "DEVICE_E",
                5,
                0.55,
                0.05,
                false
Desired Data Table
New Table( "ExampleData",
	Add Rows( 5 ),
	New Column( "index", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [0, 1, 2, 3, 4] ) ),
	New Column( "device_name", Character, "Nominal", Set Values( {"DEVICE_A", "DEVICE_B", "DEVICE_C", "DEVICE_D", "DEVICE_E"} ) ),
	New Column( "num", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1, 2, 3, 4, 5] ) ),
	New Column( "voltage_measure_V",
		Numeric,
		"Continuous",
		Set Values( [0.35, 0.4, 0.45, 0.5, 0.55] )
	New Column( "current_source_applied_A",
		Numeric,
		"Continuous",
		Set Values( [0.03, 0.52, 0.21, 0.53, 0.05] )
	New Column( "in_compliance", Numeric, "Ordinal", Format( "Best", 12 ), Set Values( [0, 0, 0, 0, 0] ) )
JSON Wizard Best Guess (but not right...)
Open(
	"$DOWNLOADS/ExampleData.json",
	JSON Settings(
		Stack( 0 ),
		Row( "/root/data/index" ),
		Row( "/root/data/data" ),
		Col(
			"/root/data/index",
			Column Name( "data.index" ),
			Fill( "Use Once" ),
			Type( "Numeric" ),
			Format( {"Best"} ),
			Modeling Type( "Continuous" )
		Col(
			"/root/data/columns",
			Column Name( "data.columns" ),
			Fill( "Use Once" ),
			Type( "JSON Lines with Headers" ),
			Format( {"Best"} ),
		Col(
			"/root/data/data",
			Column Name( "data.data" ),
			Fill( "Use Once" ),
			Type( "Pandas Values" ),
			Format( {"Best"} ),
	JSON Wizard( 1 )
Re: JSON Import Wizard with Pandas Values and Headers
Right-click and try the pandas split option.Right-click and try the pandas split option.
json = "\[
    "data": {
        "index": [
            0,
            1,
            2,
            3,
            4
        "columns": [
            "device_name",
            "num",
            "in_compliance"
        "data": [
                "DEVICE_A",
                1,
                0.35,
                0.03,
                false
                "DEVICE_B",
                2,
                0.40,
                0.52,
                false
                "DEVICE_C",
                3,
                0.45,
                0.21,
                false
                "DEVICE_D",
                4,
                0.50,
                0.53,
                false
                "DEVICE_E",
                5,
                0.55,
                0.05,
                false
open(chartoblob(json),JSON Settings(
	Stack( 0 ),
	Col(
		"/root/data",
		Column Name( "data" ),
		Fill( "Use Once" ),
		Type( "Pandas Split" ),
		Format( {"Best"} ),
json = "\[
    "data": {
        "index": [
            0,
            1,
            2,
            3,
            4
        "columns": [
            "device_name",
            "num",
            "in_compliance"
        "data": [
                "DEVICE_A",
                1,
                0.35,
                0.03,
                false
                "DEVICE_B",
                2,
                0.40,
                0.52,
                false
                "DEVICE_C",
                3,
                0.45,
                0.21,
                false
                "DEVICE_D",
                4,
                0.50,
                0.53,
                false
                "DEVICE_E",
                5,
                0.55,
                0.05,
                false
	Stack( 0 ),
	Col(
		"/root/data",
		Fill( "Use Once" ),
		Format( {"Best"} ),
robot
Very nice.  Thanks!
