Chris_Liu
JSL to generate box plot and save picture
In "44322.jmp" has 28 FAI#, I want to change the script to save 28 pictures like "44322 - Graph Builder.jpg". I know the following ":FAI_1.1&:FAI_1.2&:FAI_1.3" need change, but don't know to change to what.
Variables(
	X( :FAI_1.1, Combine( "Parallel Merged" ) ),
	X( :FAI_1.2, Position( 1 ), Combine( "Parallel Merged" ) ),
	X( :FAI_1.3, Position( 1 ), Combine( "Parallel Merged" ) ),
	Group X( Phase ),
	Color( Phase )
Re: JSL to generate box plot and save picture
Here is a modification to the script that handles the 28 FAI's found in the data.  It also adjusts the chart to compensate for the different number of columns found for each FAI.
dt = Data Table( "44322.jmp" );
New Window( "Box Plot Compaire",
	Excluded( Row State( 1 ) ) = 1;
	Excluded( Row State( 2 ) ) = 1;
	Excluded( Row State( 3 ) ) = 1;
	For( i = 2, i < N Col() + 1, i++,
// determine the number of columns for the current FAI
		nFAI = 1;
		FAI = Word( 1, Column Name( i ), "." );
		Try( If( Word( 1, Column Name( i + 1 ), "." ) == FAI, nFAI = 2 ) );
		Try( If( Word( 1, Column Name( i + 2 ), "." ) == FAI, nFAI = 3 ) );
		If(
			nFAI == 3,
				mybox = Graph Builder(
					Size( 568, 458 ),
					Show Control Panel( 0 ),
					Variables(
						X( As Column( Column Name( i ) ), Position( 1 ), Combine( "Parallel Merged" ) ),
						X( As Column( Column Name( i + 1 ) ), Position( 1 ), Combine( "Parallel Merged" ) ),
						X( As Column( Column Name( i + 2 ) ), Position( 1 ), Combine( "Parallel Merged" ) ),
						Group X( Phase ),
						Color( Phase )
					Elements(
						Box Plot( X( 1 ), X( 2 ), X( 3 ), Legend( 9 ) ),
						Points( X( 1 ), X( 2 ), X( 3 ), Legend( 10 ) ),
						Caption Box( X( 1 ), X( 2 ), X( 3 ), Legend( 11 ) )
						Dispatch(
							ScaleBox,
							{Min(
								Col Min( Column( i ) ) - (Col Max( Column( i ) ) - Col Min( Column( i ) )) /
								100
							), Max(
								Col Max( Column( i ) ) + (Col Max( Column( i ) ) - Col Min( Column( i ) )) /
								100
							), /*Inc( (col max(column(i)) - col min(column(i)))/100 ),*/ Minor Ticks( 1 ),
							Add Ref Line(
								Column( i )[1],
								"Solid",
								"Dark Red",
								Eval Insert( "LSL ^column(i)[1]^" ),
								1
							), Add Ref Line(
								Column( i )[2],
								"Solid",
								"Dark Red",
								Eval Insert( "USL ^column(i)[2]^" ),
								1
							), Add Ref Line(
								Column( i )[3],
								"Solid",
								"Dark Blue",
								Eval Insert( "Target ^column(i)[3]^" ),
								1
			nFAI == 2,
					Size( 568, 458 ),
					Variables(
						Group X( Phase ),
						Color( Phase )
					Elements(
						Dispatch(
							ScaleBox,
							{Min(
								100
							), Max(
								100
							Add Ref Line(
								Column( i )[1],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[2],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[3],
								"Solid",
								"Dark Blue",
								1
				Size( 568, 458 ),
				Variables(
					Group X( Phase ),
					Color( Phase )
				Elements(
					Dispatch(
						ScaleBox,
						{Min(
							Col Min( Column( i ) ) - (Col Max( Column( i ) ) - Col Min( Column( i ) )) / 100
						), Max(
							Col Max( Column( i ) ) + (Col Max( Column( i ) ) - Col Min( Column( i ) )) / 100
						Add Ref Line(
							Column( i )[1],
							"Solid",
							"Dark Red",
							1
						), Add Ref Line(
							Column( i )[2],
							"Solid",
							"Dark Red",
							1
						), Add Ref Line(
							Column( i )[3],
							"Solid",
							"Dark Blue",
							1
		Myboxplot = mybox << report;
		Myboxplot << save picture( FAI || ".emf", emf );
	// Increase variable i if nFAI is greater than 1
	i=i+nFAI-1;
How should those column names change? One picture for each FAI_X (where X is number which might be followed by .Y)?
		nFAI = 1;
		If(
			nFAI == 3,
					Size( 568, 458 ),
					Variables(
						Group X( Phase ),
						Color( Phase )
					Elements(
						Dispatch(
							ScaleBox,
							{Min(
								100
							), Max(
								100
							Add Ref Line(
								Column( i )[1],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[2],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[3],
								"Solid",
								"Dark Blue",
								1
			nFAI == 2,
					Size( 568, 458 ),
					Variables(
						Group X( Phase ),
						Color( Phase )
					Elements(
						Dispatch(
							ScaleBox,
							{Min(
								100
							), Max(
								100
							Add Ref Line(
								Column( i )[1],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[2],
								"Solid",
								"Dark Red",
								1
							), Add Ref Line(
								Column( i )[3],
								"Solid",
								"Dark Blue",
								1
				Size( 568, 458 ),
				Variables(
					Group X( Phase ),
					Color( Phase )
				Elements(
					Dispatch(
						ScaleBox,
						{Min(
						), Max(
						Add Ref Line(
							Column( i )[1],
							"Solid",
							"Dark Red",
							1
						), Add Ref Line(
							Column( i )[2],
							"Solid",
							"Dark Red",
							1
						), Add Ref Line(
							Column( i )[3],
							"Solid",
							"Dark Blue",
							1
	i=i+nFAI-1;
Chris_Liu
As follows, "Min(……)" can use "::" to sample? I wrote "Min( Col Min( Column( i :: i + 12 )));" & "Min( Col Min( Column( i ) :: Col Min( Column( i + 12 )));"but its error.
Min(Col Min( Column( i )), Col Min( Column( i + 1 )), Col Min( Column( i + 2 )), Col Min( Column( i + 3 )), Col Min( Column( i + 4 )), Col Min( Column( i + 5 )), Col Min( Column( i + 6 )), Col Min( Column( i + 7 )), Col Min( Column( i + 8 )), Col Min( Column( i + 9 )), Col Min( Column( i + 10 )), Col Min( Column( i + 11 )), Col Min( Column( i + 12 )));
