Wei1
JSL script Save Values in Model Driven Multivariate Control Chart
Hi!
How could I write JSL to "Save Columns -> Save Values" for saving t-square in Model Driven Multivariate Control Chart?
try use
obj << T Square Plot( SaveValues );
still cannot savevalues in new column T2
thanks
Re: JSL script Save Values in Model Driven Multivariate Control Chart
This seems to work fine for me (using JMP 17.2)
dt = Open("$SAMPLE_DATA/Quality Control/Flight Delays.jmp");
mdmcc = dt << Model Driven Multivariate Control Chart(
	Process(:AA, :CO, :DL, :F9, :FL, :NW, :UA, :US, :WN)
mdmcc << T Square Plot(Save Values);
Wei1
Hi jthi,
My JMP version is 17.0
I will try to update
Thanks
chris_dennis
Can other information be saved from the calculation?  I am creating a chart using a by variable (part).  The T Squared value can be saved to table with slight modification.  I would like to capture the number of Principal Components used for each part so I can recreate the same chart.  If I save the script from running MDMCC all parts are sent to by group with 'Set Component' defined (different levels for different parts).
Can I pull the Component level by part of the MDMCC model for later use in script?  I found a work around by doing a PCA analysis and pulling information based on the Eigenvalues.  But it takes more lines of scripting.
//get number of different parts/skus
nparts = n items(Associative Array(:Part) <<Get Keys);
for each ({i}, 1::nparts,
	mdmcc[i] << T Square Plot (Save Values)
Which values you wish to save? The values from the outline boxes? Which JMP are you using? How are you creating your MDMCC? << Get By Group Script and parsing the result could work or you could access the outline boxes and get results from those.
Edit:
JMP18 and collecting the outline box titles
dt << New Formula Column(
	Operation(Category("Date Time"), "Year Week"),
	Columns(:Flight Date)
	Process(:AA, :CO, :DL, :F9, :FL, :NW, :UA, :US, :WN),
	By(:"Year Week[Flight Date]"n),
	Group Options(Return Group(0))
aa = Associative Array();
For Each({cur_obj}, mdmcc,
	rep = Report(cur_obj);
	aa[rep << get title] = rep[OutlineBox("T² for?")] << get title;
show(aa);
with expressions you can mess with something like
	Group Options(Return Group(1))
s = mdmcc << Get ByGroup Script;
aa_res = Associative Array();
For(i = 1, i <= N Arg(s), i++,
	a = Arg(s, i);
	If(Head Name(a) == "SendToByGroup",
		sc = Extract Expr(a, Set Component(Wild()));
		If(!IsEmpty(sc),
			g = Extract Expr(a, List(Wild()))[1];
			aa_res[Char(Name Expr(g))] = Char(Name Expr(sc));
