JSL instruction to call script saved with data table?
May 30, 2014 12:00 PM(17016 views)
I'm trying to call a script saved with a data table from another JSL script. Is that possible? I've used Include() before to call a JSL file, but can't figure out how to call a script that is saved with a data table.
NamesDefaultToHere(1);
dt = Open("$SAMPLE_DATA/Big Class.JMP");
// Find out what scripts are stored
sl = dt << getTableScriptNames;
// Pick a script at random
s = sl[RandomInteger(1, NItems(sl))];
// Run it
s = dt << runScript(s);
// Get a reference to the analysis object
obj = Report(s) << getScriptableObject;
// Find out what messages this object understands
ShowProperties(obj);
