Hobbi
JSL help: How can I open an excel spreadsheets and delete duplicates?
I have my script (from the excel import wizard) as well as the example attached. All those columns are there but I just removed the data.
I am mainly looking to open an excel spreadsheet and only keep columns B and C while also deleting duplicate rows. I keep getting errors when debugging that the  Hobbi_0-1635365476937.png
This is my script so far. I don't have a duplicate delete portion because I keep trying to deal with this error.
All the spreadsheets I intend to open have the same format as the attached one. Thank you!
Clear Symbols();
names default to here(1);
path = Pick File ();
dt = Open(
	path,
	Worksheets( "Sheet1" ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 2 ),
		Data Starts on Column( 2 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 3 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
Thierry_S
Re: JSL help: How can I open an excel spreadsheets and delete duplicates?
Your Excel file does not contain the worksheet named "Sheet1" (it is called "Data" instead). Hence, JMP cannot open the file. If all your Excel files look the same, just change the value of the Worksheets variable in your script to "Data".
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
Hobbi
Oh man - something so simple. Thank you very much!
