statlearner
Repeated measures analysis data setup
Hello all!
I am trying to figure out how to set up my data to run repeated measure analysis on the attached dataset. I have different samples which are divided into two groups and those samples are tested at different time points. Output is change from baseline for 3 different attributes (x, y and z).
Also, where is option to run repeated measure in JMP Pro?
Thanks.
Re: Repeated measures analysis data setup
Did you search the JMP Community for this topic alreadyt? It has been asked a least a dozen times.
See this JMP Technical Note for details.
statlearner
@Mark_Bailey I did look it up but still had some confusion but I figured it out. Thank you.
