brandon_mcrv
Script used to work in JMP14 but not working in JMP16
Hi all,
      I just encountered 2 problems with my script in a Modal Window which used to be working fine in JMP14 but as soon as I moved over JMP16, these 2 problems were found:
1) There's an error message came out stating "deleted object reference: cc << Get Selected in access or evaluation of 'Glue',....."
2) "Cancel" button shows an error " Name Unresolved: Button in access or evaluation of 'Button', Button (-1) /*###*/ "
Below is a simplified script that is working fine in JMP14 but not in JMP16. If working correctly, the script will create a New column ("Result") stating "Pass" if the checkbox is checked, but a "Fail" if the checkbox is unchecked. About the "Cancel" button, if working properly, there'll be no error message when clicked, where it will close the Modal Window.
dt = Current Data Table();
win = New Window( "User Input",
	<<Modal,
	Lineup Box( N Col( 1 ),
		cchk = {"Pass"};
		Panel Box( "Result",
			cc = Check Box( cchk ),
			cc << Set( 1, 1 ),
			Spacer Box( Size( 1, 0 ) )
		H List Box( Spacer Box(), Button Box( "OK" ), Button Box( "Cancel" ) ),
If( win["Button"] == -1,
	win << Close Window
ctc = cc << Get Selected;
dt << New Column( "Result", character, nominal );
If( Contains( ctc, "Pass" ),
	dt:Result << Set Each Value( "Pass" )
	dt:Result << Set Each Value( "Fail" )
ErraticAttack
Re: Script used to work in JMP14 but not working in JMP16
In general I've found that JMP16 is a bit more aggressive about deleting display boxes immediately.
However, the way that I've always used Modal windows is by utilizing the OnValidate function -- this is typically reserved for determining whether the window should close (perhaps not all required inputs are filled out and you don't want the window to close via the 'OK' button.)  Just be sure to return a 1 for proper window closing.
	<<Modal
	<<On Validate(
		1
		cchk = {"Pass"};
			cc = Check Box( cchk, << Set( 1, 1 ) ),
		H List Box(
			Button Box( "OK" )
			Spacer Box( <<Set Auto Stretching( 1, 0 ) )
Jordan
ErraticAttack
	<<Modal
	<<On Validate(
		1
		cchk = {"Pass"};
		H List Box(
			Button Box( "OK" )
Jordan
brandon_mcrv
 Hi, really sorry for the late reply. I have been busy with work for the past 2 weeks. Thanks for the solution. It works and I learnt something new. Appreciate that !
