I have my script (from the excel import wizard) as well as the example attached. All those columns are there but I just removed the data.
I am mainly looking to open an excel spreadsheet and only keep columns B and C while also deleting duplicate rows. I keep getting errors when debugging that the
This is my script so far. I don't have a duplicate delete portion because I keep trying to deal with this error.
All the spreadsheets I intend to open have the same format as the attached one. Thank you!
Clear Symbols();
names default to here(1);
path = Pick File ();
dt = Open(
path,
Worksheets( "Sheet1" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Headers Start on Row( 1 ),
Data Starts on Row( 2 ),
Data Starts on Column( 2 ),
Data Ends on Row( 0 ),
Data Ends on Column( 3 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
