Aziza
JSL: close data table not responding
I have three opened data tables defined by dt_pp, dt_pp_t, dt_final and I want to close them. My script contains the following lines:
Close( dt_pp, No Save );
Close( dt_pp_t, No Save );
Close(dt_final, No Save);
If I run the whole script, it closes the two first data tables and not the last one. But if I select this particular line and run it, it works and the table closes.
What am I doing wrong/missing here?
Thank you!
Greetings
uday_guntupalli
Level VIII
Re: JSL: close data table not responding
@Aziza
          Maybe you could make the tables current before trying to close them ?
Current Data Table(dt_pp);
Close(dt_pp,"No Save");
Current Data Table(dt_pp_t);
Close(dt_pp_t,"No Save");
Current Data Table(dt_final);
Close(dt_final,"No Save");
Best
Uday
gzmorgan0
From your file names, I wonder, if your second file might be linked or still being used.
For example if the second file (dt_pp_t) was a summary of the first (dt_pp), closing dt_pp will automaticaly close dt_pp_t and the second close statement might cause an error, and the third statement is not run.
When you run your script, look at the log file (CTRL + Shift + L) to see if there is an error statement; that might help.
You did not state if you were running your script interactively, or scheduled/batch.  If a JSL statement results in a prompt when running interactively, when running remote/batch, the script will end.
Just a few ideas on where  to look.
uday_guntupalli
Level VIII
@Aziza
Best
Uday
gzmorgan0
Aziza
Thank you!
Greetings
